path: root/configs/tbs2910_defconfig
2015-09-02tbs2910: remove deprecated CONFIG_SYS_EXTRA_OPTIONSSoeren Moch
move options from CONFIG_SYS_EXTRA_OPTIONS to board specific Kconfig Signed-off-by: Soeren Moch <smoch@web.de>
2015-09-02imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig filePeng Fan
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined. If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric BĂ©nard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Marek Vasut <marex@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Soeren Moch <smoch@web.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Soeren Moch <smoch@web.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-07-03Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Conflicts: configs/tbs2910_defconfig configs/tqma6q_mba6_mmc_defconfig configs/tqma6q_mba6_spi_defconfig configs/tqma6s_mba6_mmc_defconfig configs/tqma6s_mba6_spi_defconfig include/configs/mx6_common.h Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-09tbs2910: add thermal supportSoeren Moch
2014-11-13arm: mx6: add support for TBS2910 Matrix ARM miniPCSoeren Moch
Add initial support for TBS2910 Matrix ARM miniPC. Support includes MMC, Ethernet, UARTs, HDMI, USB, SATA, PCI, I2C, RTC. Signed-off-by: Soeren Moch <smoch@web.de>
