path: root/configs/tbs2910_defconfig
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2019-01-09board: tbs2910: Remove FIT support in defconfig to reduce u-boot sizeSoeren Moch
The current defconfig build generates a u-boot.imx file that is too large for the available space on a eMMC/SD card. Installing this file overwrites the u-boot environment. So disable the unused FIT support to reduce the size of the u-boot binary. Signed-off-by: Soeren Moch <smoch@web.de>
2017-12-12ata: Migrate CONFIG_DWC_AHSATA to KconfigTuomas Tynkkynen
2017-10-30configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Convert CONFIG_CMD_HDMIDETECT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_HDMIDETECT Note that we cannot do 'default y if VIDEO' because this option is only enabled for a small subset of mx6 boards. Also this command is is not a great implementation (it doesn't use driver model). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CFB_CONSOLE_ANSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE_ANSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONSOLE_PRE_CONSOLE_BUFFER options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-02tbs2910: remove deprecated CONFIG_SYS_EXTRA_OPTIONSSoeren Moch
move options from CONFIG_SYS_EXTRA_OPTIONS to board specific Kconfig Signed-off-by: Soeren Moch <smoch@web.de>
2015-09-02imx: mx6 move TARGET_xx Kconfig option to mx6 specific Kconfig filePeng Fan
Move TARGET_xx Kconfig option based on mx6 to arch/arm/cpu/armv7/mx6/Kconfig. Add enable "CONFIG_ARCH_MX6" for boards based on mx6. Then we can choose target boards using "make ARCH=arm menuconfig" with ARCH_MX6 defined. If using original way, we have no chance to enable ARCH_MX6 when "make menuconfig". Even define CONFIG_ARCH_MX6=y in xx_defconfig, kconfig will complains "arch/../configs/platinum_titanium_defconfig:3: warning: override: TARGET_PLATINUM_TITANIUM changes choice state" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Eric BĂ©nard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Marek Vasut <marex@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Soeren Moch <smoch@web.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Soeren Moch <smoch@web.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2015-07-03Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Conflicts: configs/tbs2910_defconfig configs/tqma6q_mba6_mmc_defconfig configs/tqma6q_mba6_spi_defconfig configs/tqma6s_mba6_mmc_defconfig configs/tqma6s_mba6_spi_defconfig include/configs/mx6_common.h Signed-off-by: Tom Rini <trini@konsulko.com>
