path: root/configs/tb100_defconfig
2015-04-03board: Switch Abilis TB-100 board to Driver Model for serial portAlexey Brodkin
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org>
2015-04-03arc: re-generate defconfigsAlexey Brodkin
Before that moment our defconfigs were manually modified with addition of new options. That means once anybody wants to add another option and re-genarate defconfig with "make defconfig" there will be lots of differences. So to make future modifications more clean we'll do bulk re-generation right away. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: move SYS_MONITOR_BASE setup in KonfigAlexey Brodkin
Following SPARK ARC now has SYS_MONITOR_BASE setup via Kconfig. This makes "include/configs/*.h" cleaner and more flexible. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: select cache settings via menuconfigAlexey Brodkin
This change allows to keep board description clean and minimalistic. This is especially helpful if one board may house different CPUs with different features. It is applicable to both FPGA-based boards or those that have CPUs mounted on interchnagable daughter-boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-01-14Kconfig: move CONFIG_SYS_CLK_FREQ to KconfigAlexey Brodkin
It makes sense to specify CONFIG_SYS_CLK_FREQ in "configs/xx_defconfig" instead of "include/configs/xxx.h" because then header will be reusable across boards with different CPU clocks. Also this nice to have an ability for end user to tune this value himself via "menuconfig". For now I'm only applying this change to all ARC configs because otherwise scope of change will be huge. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Hans de Goede <hdegoede@redhat.com> cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
