path: root/configs/taurus_defconfig
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-19axm/taurus: Enable tiny printf in SPLTom Rini
Both of these boards are very close to their limit and with some toolchains such as gcc 5.x are too large. Switch to tiny printf to reclaim some size. Signed-off-by: Tom Rini <trini@konsulko.com>
2014-11-17arm, at91, spl: add spl support for the taurus boardHeiko Schocher
replaces the at91bootstrap code with SPL code. make the spl image with: ./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin this writes the length of the spl image into the 6th execption vector. This is needed from the ROM bootloader. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
