path: root/configs/taishan_defconfig
2015-10-27taishan: DropTom Rini
This board has not compiled for me for quite some time due to size constraints, remove. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
