path: root/configs/sunxi_Gemei_G9_defconfig
2015-01-22sunxi: Add Gemei G9 (Allwinner A10/sun4i) tabletPriit Laes
Gemei G9 is an A10 based tablet, with 1G RAM, 16G NAND, 1024x768 IPS LCD display, stereo speakers, 1.3MP front camera and 5 MP rear camera, 8000mAh battery, GT901 2+1 touchscreen, Bosch BMA250 accelerometer and RTL8188CUS USB wifi. It also has MicroSD slot, miniHDMI, 1 x MicroUSB OTG port and 1 x MicroUSB host port and 3.5mm headphone jack. More details are available at: http://linux-sunxi.org/Gemei_G9 Signed-off-by: Priit Laes <plaes@plaes.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
