path: root/configs/stv0991_defconfig
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-14net: phy: micrel: Allow KSZ8xxx and KSZ90x1 to be used togetherJames Byrne
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns that you shouldn't select both of them due to a device ID clash between the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately boards like the SAMA5D3xEK do contain both types of PHY, but fortunately the Linux Micrel PHY driver provides a solution by using different PHY ID and mask values to distinguish these chips. This commit contains the following changes: - The PHY ID and mask values for the KSZ9021 and the KS8721 now match those used by the Linux driver. - The warnings about not enabling both drivers have been removed. - The description for PHY_MICREL_KSZ8XXX has been corrected (these are 10/100 PHYs, not GbE PHYs). - PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE since this is selected by PHY_MICREL_KSZ90X1. - All of the relevant defconfig files have been updated now that PHY_MICREL_KSZ8XXX does not default to 'Y'. Signed-off-by: James Byrne <james.byrne@origamienergy.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2016-09-16spear: Use upper case for CONFIG optionsSimon Glass
There are a few options which use lower case. We should use upper case for all CONFIG options. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-03stv0991: move OF_CONTROL config to defconfigVikas Manocha
Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-07-03stv0991: enable saving enrironment in spi flashVikas Manocha
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-10stv0991: fdt: add stv0991 device treeVikas Manocha
This patch adds device tree for the ST Micro stv0991 board & enables device tree control. Progressively device tree support for the drivers being used will also be added. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18ARM: stv0991: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-02-13dm: stv0991: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-09stv0991: Add basic stv0991 architecture supportVikas Manocha
stv0991 architecture support added. It contains the support for following blocks - Timer - uart Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Add arch/arm/cpu/armv7/Makefile hunk] Signed-off-by: Tom Rini <trini@ti.com>
