path: root/configs/strider_cpu_dp_defconfig
2017-05-22Convert CONFIG_CMD_IOLOOP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IOLOOP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGAD Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-06strider: Support cpu-dp flavorDirk Eibach
There is new strider cpu flavor with DisplayPort video. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
