path: root/configs/strider_cpu_defconfig
2017-05-22Convert CONFIG_CMD_IOLOOP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IOLOOP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGAD Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-12mpc83xx: Add strider boardDirk Eibach
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> [trini: Drop setting CONFIG_SYS_GENERIC_BOARD, this is always true now] Signed-off-by: Tom Rini <trini@konsulko.com>
