path: root/configs/stout_defconfig
2017-04-08arm: rmobile: Remove default value of Kconfig from defconfigNobuhiro Iwamatsu
This removes CONFIG_BOOTSTAGE_USER_COUNT, CONFIG_BOOTSTAGE_STASH_ADDR and CONFIG_BOOTSTAGE_STASH_SIZE from defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche - Salvator-x Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Update defconfigNobuhiro Iwamatsu
This updated defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-08-31arm: rmobile: Add Stout board supportVladimir Barinov
Stout is an entry level development board based on R-Car H2 SoC (R8A7790) This commit supports the following peripherals: - SCIFA, I2C, Ethernet, QSPI, SDHI0/2, CPLD Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
