The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
Some STM32 MCU's board need their SYS_MALLOC_F_LEN value enlarged
to avoid the "alloc space exhausted" error message during their boot
process.
Use the default SYS_MALLOC_F_LEN value which is set to 0x2000 in
Kconfig.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
All these files are add for support rt-thread art-pi board
- add board/st/stm32h750-art-pi, defconfig, header support for u-boot
for more information about art-pi, please goto:
https://art-pi.gitee.io/website/
Signed-off-by: dillon min <dillon.minfei@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
