Some STM32 MCU's board need their SYS_MALLOC_F_LEN value enlarged
to avoid the "alloc space exhausted" error message during their boot
process.
Use the default SYS_MALLOC_F_LEN value which is set to 0x2000 in
Kconfig.
Signed-off-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
These flags was defined and callbacks linked to these flags are empty
and only returning 0.
Remove BOARD_EARLY_INIT_F and BOARD_LATE_INIT flags for these stm32 boards.
CONFIG_BOARD_LATE_INIT
Have this symbol follow the pattern of all other such symbols.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Network support was never added on this board, disable
CONFIG_NET flag to avoid following warning:
===================== WARNING ======================
This board does not use CONFIG_DM_ETH (Driver Model
for Ethernet drivers). Please update the board to use
CONFIG_DM_ETH before the v2020.07 release. Failure to
update by the deadline may result in board removal.
See doc/driver-model/migration.rst for more info.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Building with CONFIG_OF_EMBED generates build warnings, as it should
only be used for debugging purposes.
Remove CONFIG_OF_EMBED from all stm32 config files which are using
this flag.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Add DISTRO_DEFAULT support to be able to boot on
mmc by default on boot.
Remove CONFIG_CMD_CACHE from include/configs/stm32h7xx.h
and enable it in stm32h7xx_defconfig
Enable networking command only when NET is enabled.
And remove selecting NET for CMD_NET
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Enable CMD_GPT/EXT2/EXT4/EXT4_WRITE/FAT_FS_GENERIC flags
Enable CMD_MMC, DM_MMC and STM32_SDMMC2 flags
This patch adds support for stm32h7 soc family, stm32h743
discovery and evaluation boards.
For more information about STM32H7 series, please visit:
http://www.st.com/en/microcontrollers/stm32h7-series.html
