to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
This config file is shared between stm32f746-disco and stm32f769-disco.
These 2 boards doesn't embed the same qspi flash (Micron n25q128a on
f746-disco, Macronix mx66l51235l on f769-disco).
To be able to use Macronix mx66l51235l on F769-disco, flags
SPI_FLASH_MACRONIX must be enabled.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Allows to boot linux distribution
Since commit 8f651ca60ba1 ("pinctrl: stm32: Add get_pins_count() ops")
stm32f746-disco can't boot.
This is due to new memory allocation into STM32 pinctrl driver,
increase SYS_MALLOC_F_LEN from 0xC00 to 0xE00.
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Remove CONFIG_CMD_CACHE from include/configs/stm32f746-disco.h
and enable it in stm32f746-disco_defconfig
CONFIG_BLK config flag becomes mandatory, enable it.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Signed-off-by: yannick fertre <yannick.fertre@st.com>
Enable DOS_PARTITION for boards STM32F429-eval, STM32F469-disco
and STM32F746-disco.
This allows to read FAT partition on mmc.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Move system flags from defconfig to mach-stm32/Kconfig
Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
Now this driver is used across stm32f4, stm32f7 and stm32h7
SoCs family, give it a generic name.
STM32F469-disco embeds an arm_pl180 mmc IP, so
enable CMD_MMC, DM_MMC and ARM_PL180_MMCI flags.
Also enables all filesystem command related flags :
_ CMD_EXT2
_ CMD_EXT4
_ CMD_FAT
_ CMD_FS_GENERIC
_ CMD_GPT
_ CMD_BOOTZ
This allows to add rcc MFD support to stm32f746-disco board
This rcc MFD driver manages clock and reset for STM32 SoCs family
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
Add CONFIG_STM32X7_SERIAL as a Kconfig option.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
This commit supports booting from stm32 internal nor flash. spl U-Boot
initializes the sdram memory, copies next image (e.g. standard U-Boot)
to sdram & then jumps to entry point.
Here are the flash memory addresses for U-Boot-spl & standard U-Boot:
- spl U-Boot : 0x0800_0000
- standard U-Boot : 0x0800_8000
To compile u-boot without spl: Remove SUPPORT_SPL configuration
(arch/arm/mach-stm32/Kconfig)
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
[trini: Rework Kconfig logic a bit]
With this gpio driver supporting DM, there is no need to enable clocks
for different gpios (for pin muxing) in the board specific code.
Need to increase the allocatable area required before relocation from 0x400 to
0xC00 becuase of 10 new gpio devices(& new gpio class) added in device tree.
cc: Christophe KERELLO <christophe.kerello@st.com>
This driver uses the same pin control binding as that of linux, binding
document of this patch is copied from linux. One addition done is for
GPIO input and output mode configuration which was missing.
add basic clock driver support for stm32f7 to enable clocks required by
the peripherals.
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
This patch adds support for the QSPI IP found in stm32f7 devices.
Signed-off-by: Michael Kurz <michi.kurz@gmail.com>
This patch adds glue code required for enabling the designware
mac on stm32f7 devices.
This patch adds the DTS source files needed for stm32f746-disco board
The files are based on the stm32f429/469 files from current linux
kernel.
Source for "arch/arm/dts/armv7-m.dtsi": Linux: "arch/arm/boot/dts/armv7-m.dtsi"
Acked-by: Vikas MANOCHA <vikas.manocha@st.com>
CONFIG_BOARD_EARLY_INIT_F
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
