path: root/configs/stm32f746-disco_defconfig
2017-07-31serial: stm32x7: Convert CONFIG_STM32X7_SERIAL to KconfigPatrice Chotard
Add CONFIG_STM32X7_SERIAL as a Kconfig option. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2017-06-09stm32: stm32f7: add spl build supportVikas Manocha
This commit supports booting from stm32 internal nor flash. spl U-Boot initializes the sdram memory, copies next image (e.g. standard U-Boot) to sdram & then jumps to entry point. Here are the flash memory addresses for U-Boot-spl & standard U-Boot: - spl U-Boot : 0x0800_0000 - standard U-Boot : 0x0800_8000 To compile u-boot without spl: Remove SUPPORT_SPL configuration (arch/arm/mach-stm32/Kconfig) Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Rework Kconfig logic a bit] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-08stm32f7: remove duplicate configsVikas Manocha
2017-05-08stm32f7: use stm32f7 gpio driver supporting driver modelVikas Manocha
With this gpio driver supporting DM, there is no need to enable clocks for different gpios (for pin muxing) in the board specific code. Need to increase the allocatable area required before relocation from 0x400 to 0xC00 becuase of 10 new gpio devices(& new gpio class) added in device tree. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08stm32f7: sdram: move sdram driver code to ram drivers areaVikas Manocha
2017-03-17PINCTRL: stm32f7: add pin control driverVikas Manocha
This driver uses the same pin control binding as that of linux, binding document of this patch is copied from linux. One addition done is for GPIO input and output mode configuration which was missing. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-17clk: stm32f7: add clock driver for stm32f7 familyVikas Manocha
add basic clock driver support for stm32f7 to enable clocks required by the peripherals. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28ARM: SPI: stm32: add stm32f746 qspi driverMichael Kurz
This patch adds support for the QSPI IP found in stm32f7 devices. Signed-off-by: Michael Kurz <michi.kurz@gmail.com>
2017-01-28net: stm32: add designware mac glue code for stm32Michael Kurz
This patch adds glue code required for enabling the designware mac on stm32f7 devices. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-28ARM: DTS: stm32: add stm32f746-disco device tree filesMichael Kurz
This patch adds the DTS source files needed for stm32f746-disco board The files are based on the stm32f429/469 files from current linux kernel. Source for "arch/arm/dts/armv7-m.dtsi": Linux: "arch/arm/boot/dts/armv7-m.dtsi" Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Vikas MANOCHA <vikas.manocha@st.com>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-24stm32: add support for stm32f7 & stm32f746 discovery boardVikas Manocha
This patch adds support for stm32f7 family & stm32f746 board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
