path: root/configs/stm32f469-discovery_defconfig
2019-05-06configs: stm32f469-disco: Disable PINCTRL_FULL flagPatrice Chotard
Disable unused PINCTRL_FULL flag. Series-cc: pde, cke, pch, uboot-stm32 Cover-letter: SPI flash STM32 MCU's fixes This series update MCU's DT in order to fix SPI flash configuration: - Adds MPU region dedicated for SPI flash used in memory mapped mode. - Fixes compatible string. - Fixes memory map size. - Updates spi-tx-bus-width and spi-rx-bus-width property values. - Adds QSPI flash support for STM32F469-disco board END Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-05-06configs: stm32f469-disco: Enable QSPI relative flagsPatrice Chotard
Enable CMD_SF, MTD, DM_SPI_FLASH, SPI_FLASH, SPI, DM_SPI and STM32_QSPI flags to be able to use the embedded n25q128a QSPI flash on stm32f469-disco board. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-02-13efi_loader: CMD_BOOTEFI_HELLO_COMPILE in configsHeinrich Schuchardt
It should not be necessary to adjust CMD_BOOTEFI_HELLO_COMPILE in config files. arch/arm/lib/crt0_arm_efi.S cannot be compiled in thumbs mode. We can disable CMD_BOOTEFI_HELLO_COMPILE for CONFIG_CPU_V7M. So there is no longer a need to disable it in stm32 configs. helloworld.efi can be built without problems on x86_64. So there is no need to disable it in chromebook_link64_defconfig and qemu-x86_64_defconfig. Same is true for ARM V7A. So do not disable CMD_BOOTEFI_HELLO_COMPILE in kp_imx6q_tpc_defconfig. Some architecture checks are already make for EFI_LOADER. There is no need to repeat them for CMD_BOOTEFI_HELLO_COMPILE Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrice.Chotard@st.com Signed-off-by: Alexander Graf <agraf@suse.de>
2019-01-15configs: stm32: Remove CONFIG_OF_EMBEDPatrice Chotard
Building with CONFIG_OF_EMBED generates build warnings, as it should only be used for debugging purposes. Remove CONFIG_OF_EMBED from all stm32 config files which are using this flag. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32f469-discovery: Add DISTRO_DEFAULT supportPatrice Chotard
Add DISTRO_DEFAULT support to be able to boot on mmc by default on boot. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-03configs: stm32f469-disco: Enable CONFIG_BLKPatrice Chotard
CONFIG_BLK config flag becomes mandatory, enable it. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-13configs: stm32: Enable DOS_PARTITION for STM32F4/F7 boardsPatrice Chotard
Enable DOS_PARTITION for boards STM32F429-eval, STM32F469-disco and STM32F746-disco. This allows to read FAT partition on mmc. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-19configs: stm32: move config flag from defconfig to KconfigPatrice Chotard
Move system flags from defconfig to mach-stm32/Kconfig Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-19serial: stm32: Rename serial_stm32x7.c to serial_stm32.cPatrice Chotard
Now this driver is used across stm32f4, stm32f7 and stm32h7 SoCs family, give it a generic name. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-10board: stm32: add stm32f469-discovery board supportPatrice Chotard
This board offers : _ STM32F469NIH6 microcontroller featuring 2 Mbytes of Flash memory and 324 Kbytes of RAM in BGA216 package _ On-board ST-LINK/V2-1 SWD debugger, supporting USB reenumeration capability: _ Mbed-enabled (mbed.org) _ USB functions: USB virtual COM port, mass storage, debug port _ 4 inches 800x480 pixel TFT color LCD with MIPI DSI interface and capacitive touch screen _ SAI Audio DAC, with a stereo headphone output jack _ 3 MEMS microphones _ MicroSD card connector _ I2C extension connector _ 4Mx32bit SDRAM _ 128-Mbit Quad-SPI NOR Flash _ Reset and wake-up buttons _ 4 color user LEDs _ USB OTG FS with Micro-AB connector _ Three power supply options: _ Expansion connectors and Arduinoâ„¢ UNO V3 connectors Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
