path: root/configs/stm32f429-discovery_defconfig
2016-11-27efi_loader: Allow to compile helloworld.efi w/o bundling itAlexander Graf
Today we can compile a self-contained hello world efi test binary that allows us to quickly verify whether the EFI loader framwork works. We can use that binary outside of the self-contained test case though, by providing it to a to-be-tested system via tftp. This patch separates compilation of the helloworld.efi file from including it in the u-boot binary for "bootefi hello". It also modifies the efi_loader test case to enable travis to pick up the compiled file. Because we're now no longer bloating the resulting u-boot binary, we can enable compilation always, giving us good travis test coverage. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-20stm32: move stm32 specific code to mach-stm32Vikas Manocha
This patch moves stm32 sources at one place, with this armv7m now contains only generic stuff. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2015-04-22stm32f4: Add support for stm32f429-discovery boardrev13@wp.pl
Signed-off-by: Kamil Lulko <rev13@wp.pl> Reviewed-by: Tom Rini <trini@konsulko.com>
