path: root/configs/stm32f429-discovery_defconfig
2018-01-19configs: stm32: move config flag from defconfig to KconfigPatrice Chotard
Move system flags from defconfig to mach-stm32/Kconfig Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-19serial: stm32: Rename serial_stm32x7.c to serial_stm32.cPatrice Chotard
Now this driver is used across stm32f4, stm32f7 and stm32h7 SoCs family, give it a generic name. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-10board: stm32f429-disco: switch to DM STM32 pinctrl and gpio driverPatrice Chotard
Use available DM stm32f7_gpio.c and pinctrl_stm32.c drivers instead of board GPIO initialization. Remove stm32_gpio.c which is no more used and migrate structs stm32_gpio_regs and stm32_gpio_priv into arch-stm32f4/gpio.h to not break compilation. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-10board: stm32f429-disco: switch to DM STM32 clock driverPatrice Chotard
Use available DM clk_stm32f.c driver instead of dedicated mach-stm32/stm32f4/clock.c. Migrate periph_clock defines from stm32_periph.h directly in CLK driver. These periph_clock defines will be removed when STMMAC, TIMER2 and SYSCFG drivers will support DM CLK. Enable also CLK flag. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-10board: stm32f429-disco: switch to DM STM32 serial driverPatrice Chotard
Remove serial_stm32.c driver and uart init from board file, use available DM serial_stm32x7.c driver compatible for STM32F4/F7 and H7 SoCs. The serial_stm32x7.c driver will be renamed later with a more generic name as it's shared with all STM32 Socs. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-10configs: stm32f429-disco: enable MISC, STM32_RCC, DM_RESET and STM32_RESETPatrice Chotard
This allows to support rcc MFD driver. By enabling all these flags, we need to increase malloc area to avoid crash during early stage. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-10board: stm32f429-discovery: switch to DM STM32 sdram driverPatrice Chotard
Use available DM stm32_sdram.c driver instead of board SDRAM initialization. For that, enable OF_CONTROL, OF_EMBED and STM32_SDRAM flags. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2016-11-27efi_loader: Allow to compile helloworld.efi w/o bundling itAlexander Graf
Today we can compile a self-contained hello world efi test binary that allows us to quickly verify whether the EFI loader framwork works. We can use that binary outside of the self-contained test case though, by providing it to a to-be-tested system via tftp. This patch separates compilation of the helloworld.efi file from including it in the u-boot binary for "bootefi hello". It also modifies the efi_loader test case to enable travis to pick up the compiled file. Because we're now no longer bloating the resulting u-boot binary, we can enable compilation always, giving us good travis test coverage. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-20stm32: move stm32 specific code to mach-stm32Vikas Manocha
This patch moves stm32 sources at one place, with this armv7m now contains only generic stuff. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2015-04-22stm32f4: Add support for stm32f429-discovery boardrev13@wp.pl
Signed-off-by: Kamil Lulko <rev13@wp.pl> Reviewed-by: Tom Rini <trini@konsulko.com>
