path: root/configs/stih410-b2260_defconfig
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-08board: STiH410-B2260: update environment variablePatrice Chotard
Update environment variable by updating: _ BOOT_TARGET_DEVICE _ CONFIGS_BOOTARGS _ kernel_addr_r, fdtfile, fdt_addr_r, scriptaddr, fdt_high, intird_high Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-22STiH410-B2260: enable USB, fastboot, reset, PHY related flagsPatrice Chotard
2017-03-14board: Add STMicroelectronics STiH410-B2260 supportPatrice Chotard
This is a 96Board compliant board based on STiH410 SoC: - 1GB DDR - On-Board USB combo WiFi/Bluetooth RTL8723BU with PCB soldered antenna - Ethernet 1000-BaseT - SATA - HDMI - 2 x USB2.0 type A - 1 x USB2.0 type micro-AB - SD card slot - High speed connector (SD/I2C/USB interfaces) - Low speed connector (UART/I2C/GPIO/SPI/PCM interfaces) Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
