path: root/configs/spear320_usbtty_pnor_defconfig
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16spear: Use upper case for CONFIG optionsSimon Glass
There are a few options which use lower case. We should use upper case for all CONFIG options. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-17i2c: config: Move SYS_I2C_DW to KconfigStefan Roese
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config header to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
