path: root/configs/sopine_baseboard_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-08sunxi: add a defconfig for SoPine w/ official baseboardIcenowy Zheng
The SoPine is a SoM by Pine64, with an Allwinner A64 SoC, a LPDDR3 DRAM chip, an AXP803 PMIC, a SPI NOR Flash and a MicroSD slot. The card detect pin of the MicroSD slot is broken, however, it doesn't matter as the design of SoPine didn't allow hot-swapping the MicroSD card (The MicroSD slot is at the back of the SoM, and when the SoM is installed on the baseboard, it's nearly impossible to remove the MicroSD). The official baseboard of it is a board with nearly the same connectors with the original Pine64+, with the MicroUSB power jack replaced, and at the position of MicroSD slot a eMMC module slot is added. Add support for SoPine with the official baseboard by adding its defconfig file. It still uses the device tree of Pine64, however, it will change after a proper device tree of SoPine with baseboard is accepted by Linux mainline. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> [Update board/sunxi/MAINTAINERS] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
