path: root/configs/socfpga_sockit_defconfig
2023-03-27configs: Resync with savedefconfigTom Rini
2023-02-17configs: Resync with savedefconfigTom Rini
2022-12-05Convert CONFIG_SYS_TIMER_COUNTS_DOWN to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_TIMER_COUNTS_DOWN Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-11-10Convert CONFIG_SYS_MMC_MAX_BLK_COUNT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MMC_MAX_BLK_COUNT Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2022-09-01Convert CONFIG_SYS_L2_PL310 to KconfigPhilip Oberfichtner
This converts CONFIG_SYS_L2_PL310 to Kconfig. For omap2 and mvebu the 'select SYS_L2_PL310' locations were determined using ./tools/moveconfig -i CONFIG_SYS_L2_PL310. For mx6 I manually chose ARCH_MX6 as 'select' location. The correctness has been verified using $ ./tools/moveconfig.py -f ARCH_MX6 ~SYS_L2_PL310 ~SYS_L2CACHE_OFF 0 matches That means whenever an ARCH_MX6 board had SYS_L2_PL310 disabled, this was correctly reflected in SYS_L2CACHE_OFF. Thus it's safe to insert the 'select' statement under ARCH_MX6. Signed-off-by: Philip Oberfichtner <pro@denx.de>
2022-08-23configs: Resync with savedefconfigTom Rini
2022-06-06Convert CONFIG_SPL_STACK to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_STACK Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Migrate CUSTOM_SYS_INIT_SP_ADDR to Kconfig using system-constants.hTom Rini
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR - Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack pointer directly, otherwise we use the common calculation. - On some platforms that were using the standard calculation but did not set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them. - On a small number of platforms that were not subtracting GENERATED_GBL_DATA_SIZE do so now via the standard calculation. - CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most board config header files. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_BSS_MAX_SIZE et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_BSS_MAX_SIZE CONFIG_SPL_MAX_FOOTPRINT Note that the da850evm platforms were violating the "only use one" rule here, and so now hard-code their BSS limit. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_PAD_TO et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE CONFIG_TPL_PAD_TO CONFIG_TPL_MAX_SIZE Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the existing places. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SYS_MAXARGS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MAXARGS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_CLOCKS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CLOCKS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-01-21Convert CONFIG_TIMESTAMP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_TIMESTAMP Signed-off-by: Simon Glass <sjg@chromium.org>
2021-11-01configs: Resync with savedefconfigTom Rini
2021-08-31Convert CONFIG_SYS_MALLOC_LEN to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MALLOC_LEN Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-08-10configs: Resync with savedefconfigTom Rini
2021-07-26configs: Resync with savedefconfigTom Rini
2021-06-28Merge tag 'v2021.07-rc5' into nextTom Rini
Prepare v2021.07-rc5 # gpg: Signature made Mon 28 Jun 2021 03:39:36 PM EDT # gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C # gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate] # Conflicts: # configs/am64x_evm_r5_defconfig
2021-06-28configs: Resync with savedefconfigTom Rini
2021-06-08usb: dfu: Migrate CONFIG_SYS_DFU_DATA_BUF_SIZE and ↵Aswath Govindraju
CONFIG_SYS_DFU_MAX_FILE_SIZE to Kconfig Currently the config options CONFIG_SYS_DFU_DATA_BUF_SIZE and CONFIG_SYS_DFU_MAX_FILE_SIZE are being set in include/configs/<board>.h files and also in <board_name>_defconfig files without a Kconfig option. It is easier for users to set these configs in defconfig files than in config header files as they are a part of the source code. Add Kconfig symbols, and update the defconfigs by using tools/moveconfig.py script. Suggested-by: Pratyush Yadav <p.yadav@ti.com> Signed-off-by: Aswath Govindraju <a-govindraju@ti.com> Acked-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Acked-by: Matthias Brugger <mbrugger@suse.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2021-05-11configs: Resync with savedefconfigTom Rini
2020-10-09configs: Resync with savedefconfigTom Rini
2020-07-06Merge branch 'next'Tom Rini
Merge all outstanding changes from the current next branch in now that we have released.
2020-07-06configs: Resync with savedefconfigTom Rini
2020-06-26spi: Enable missing CONFIG_SPL_DM_SPI supportTom Rini
Due to how the Makefile logic is we currently get DM_SPI support in SPL enabled by having DM_SPI enabled for full U-Boot but not having CONFIG_SPL_DM_SPI set. Add this missing option to boards that were inadvertently making use of it. Cc: Adam Ford <aford173@gmail.com> Cc: Akash Gajjar <akash@openedev.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Andy Yan <andy.yan@rock-chips.com> Cc: Anup Patel <anup.patel@wdc.com> Cc: Atish Patra <atish.patra@wdc.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Chee Hong Ang <chee.hong.ang@intel.com> Cc: Chin-Liang See <clsee@altera.com> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Levin Du <djw@t-chip.com.cn> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Mike Looijmans <mike.looijmans@topic.nl> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Palmer Dabbelt <palmer@dabbelt.com> Cc: Patrick Delaunay <patrick.delaunay@st.com> Cc: Paul Walmsley <paul.walmsley@sifive.com> Cc: Pavel Machek <pavel@denx.de> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Suniel Mahesh <sunil@amarulasolutions.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Wolfgang Grandegger <wg@aries-embedded.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-22Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
- Assorted fixes
2019-11-20ARM: socfpga: Fix default mtdpartsMarek Vasut
The default mtdparts value grew a trailing zero during the Kconfig conversion. This is because the mtdparts value in the header file had a \0 at the end, which got misconverted into plain 0 instead of being dropped. Signed-off-by: Marek Vasut <marex@denx.de> Fixes: 43ede0bca7fc ("Kconfig: Migrate MTDIDS_DEFAULT / MTDPARTS_DEFAULT") Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-25mtd: spi: Clean up usage of CONFIG_SPI_FLASH_MTDFrieder Schrempf
Most boards currently use SPI_FLASH_MTD only in U-Boot proper, not in SPL. They often rely on hacks in the board header files to include this option conditionally. To be able to fix this, we previously introduced a separate option SPL_SPI_FLASH_MTD. Therefore we can now adjust the Makefile and change the code in sf_probe.c and sf_internal.h to use CONFIG_IS_ENABLED(SPI_FLASH_MTD). We also need to move all occurences of CONFIG_SPI_FLASH_MTD from the header files to the according defconfigs. The affected boards are socfpga, aristainetos, cm_fx6, display5, ventana, rcar-gen2, dh_imx6 and da850evm. We do this all in one patch to guarantee bisectibility. This change was tested with buildman to make sure it does not introduce any regressions by comparing the resulting binary sizes. Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-10-06arm: socfpga: disable CONFIG_SPL_WDT for gen5 and a10Simon Goldschmidt
These boards don't have a watchdog enabled in SPL, so make sure CONFIG_SPL_WDT is not enabled. Fixes: commit 6874cb72204f ("watchdog: Split WDT from SPL_WDT") Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-25arm: socfpga: imply/default common config optionsSimon Goldschmidt
This commit moves common config options used in all socfpga boards to select/imply in Kconfig. This both cleans up the defconfig files as well as makes future changes easier. Options implied/defaulted for all sub-arches: - SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS Options implied/defaulted for implied for A10 & gen5: - FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE Options implied/defaulted for gen5: - SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-01-07configs: Resync with savedefconfigTom Rini
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-28configs: Resync with savedefconfigTom Rini
2018-04-17configs: socfpga: disable EFI and ISO partition typesDinh Nguyen
None of the SoCFPGA platforms will support EFI/ISO partition types that is needed for DISTRO_DEFAULTS. SoCFPGA bootroom will only support 0xa2 partition type. This is needed to help limit the size of the SPL to within the 64k limit that is required for SoCFPGA. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-17configs: socfpga: add DM_RESETDinh Nguyen
Add the DM reset driver to socfpga defconfigs. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
