Instead of having these defines in a header file, move them to
a simple text file.
Signed-off-by: Holger Brunck <holger.brunck@hitachienergy.com>
CONFIG_SYS_TIMER_COUNTS_DOWN
CONFIG_SYS_MMC_MAX_BLK_COUNT
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
This converts CONFIG_SYS_L2_PL310 to Kconfig.
For omap2 and mvebu the 'select SYS_L2_PL310' locations were
determined using ./tools/moveconfig -i CONFIG_SYS_L2_PL310.
For mx6 I manually chose ARCH_MX6 as 'select' location. The
correctness has been verified using
$ ./tools/moveconfig.py -f ARCH_MX6 ~SYS_L2_PL310 ~SYS_L2CACHE_OFF
0 matches
That means whenever an ARCH_MX6 board had SYS_L2_PL310 disabled, this
was correctly reflected in SYS_L2CACHE_OFF. Thus it's safe to insert
the 'select' statement under ARCH_MX6.
Signed-off-by: Philip Oberfichtner <pro@denx.de>
CONFIG_SYS_BOOTM_LEN
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
Tighten up symbol dependencies in a number of places. Ensure that a SPL
specific option has at least a direct dependency on SPL. In places
where it's clear that we depend on something more specific, use that
dependency instead. This means in a very small number of places we can
drop redundant dependencies.
Reported-by: Pali Rohár <pali@kernel.org>
CONFIG_SPL_STACK
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SYS_MAXARGS
CONFIG_CLOCKS
CONFIG_BOOT_RETRY_TIME
CONFIG_BOOT_RETRY_MIN
CONFIG_RESET_TO_RETRY
We also introduce CONFIG_BOOT_RETRY to gate these options, and clean up
the associated Makefile entry and C code for picking default values of
CONFIG_BOOT_RETRY_MIN.
CONFIG_BOOTFILE
CONFIG_WATCHDOG_TIMEOUT_MSECS
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_MISC_INIT_F
CONFIG_MISC_INIT_R
CONFIG_SYS_NAND_U_BOOT_LOCATIONS
CONFIG_SYS_NAND_U_BOOT_OFFS
CONFIG_SYS_NAND_ONFI_DETECTION
Rename these options so that CONFIG_IS_ENABLED can be used with them.
[trini: Fixup some incorrect renames]
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Merge all outstanding changes from the current next branch in now that
we have released.
CONFIG_BOOTARGS
Add and enable RTC-backed boot counter on ABB SECU1 platform.
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Add initial support for the ABB SECU board, which is an ArriaV-based
SoCFPGA system with ethernet and booting from Denali NAND.
Signed-off-by: Holger Brunck <holger.brunck@ch.abb.com>
