path: root/configs/socfpga_is1_defconfig
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-07ARM: socfpga: use the default CONFIG_BOOTDELAY=2Masahiro Yamada
This option controls how long it should be paused before entering the auto-boot mode. The default value from Kconfig should be fine except socfpga_vining_fpga_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-01ARM: socfpga: move CONFIG_BOOTDELAY to Kconfig for IS1 boardMasahiro Yamada
This recently added board missed the tree-wide migration of CONFIG_BOOTDELAY. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Pavel Machek <pavel@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2016-06-08ARM: socfpga: add support for IS1 boardPavel Machek
This adds support for IS1 board. Pretty usual socfpga board, 256MB of RAM, does not have MMC, two SPI chips, one ethernet port, two additional ethernet ports connected to the FPGA. Signed-off-by: Pavel Machek <pavel@denx.de>
