path: root/configs/socfpga_de1_soc_defconfig
2019-04-25arm: socfpga: imply/default common config optionsSimon Goldschmidt
This commit moves common config options used in all socfpga boards to select/imply in Kconfig. This both cleans up the defconfig files as well as makes future changes easier. Options implied/defaulted for all sub-arches: - SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS Options implied/defaulted for implied for A10 & gen5: - FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE Options implied/defaulted for gen5: - SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-28configs: Resync with savedefconfigTom Rini
2018-04-17configs: socfpga: disable EFI and ISO partition typesDinh Nguyen
None of the SoCFPGA platforms will support EFI/ISO partition types that is needed for DISTRO_DEFAULTS. SoCFPGA bootroom will only support 0xa2 partition type. This is needed to help limit the size of the SPL to within the 64k limit that is required for SoCFPGA. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-17configs: socfpga: add DM_RESETDinh Nguyen
Add the DM reset driver to socfpga defconfigs. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-17configs: socfpga: convert i2c to dmDinh Nguyen
Enable DM I2C driver on SoCFPGA platforms. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-25arm: socfpga: allow configs without network supportSimon Goldschmidt
Currently, socfpga_common.h does not allow configurations without network support. This is because CONFIG_CMD_PXE is defined in this file and distro mode has DHCP hard-coded as available. Fix this by moving CONFIG_CMD_PXE and CONFIG_MENU to the defconfigs and by making DHCP optional in BOOT_TARGET_DEVICES(func). Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-01-09ARM: socfpga: Enable part command for socfpga platformAndrey Zhizhikin
Enable CONFIG_CMD_PART item, as default environment requires it and complains this command in unknown. Signed-off-by: Andrey Zhizhikin <andrey.z@gmail.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-07-26kconfig: Convert FPGA_SOCFPGA configuration to KconfigTien Fong Chee
This converts the following to Kconfig: CONFIG_FPGA_SOCFPGA Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-04-14arm: socfpga: DE1 use environment in common headerDalon Westergreen
This removes the default environment from the de1 headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot. This board does not have a devicetree in the upstream kernel source so set devicetree to socfpga_cyclone5_de1_soc.dtb. Signed-off-by: Dalon Westergreen <dwesterg@gmail.com> Acked-by: Marek Vasut <marex@denx.de> -- Changes in V2: - Remove unneeded CONFIG_BOOTFILE - set devicetree name to match socfpga_{fpga model}_{board model}.dts pattern
2017-03-18spl: Convert CONFIG_SPL_ABORT_ON_RAW_IMAGE into a positive optionAndrew F. Davis
CONFIG_SPL_ABORT_ON_RAW_IMAGE causes SPL to abort and move on when it encounters RAW images, express this same functionality as a positive option enabling support for RAW images: CONFIG_SPL_RAW_IMAGE_SUPPORT Also move uses of this to defconfigs. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Rework Kconfig logic a little, move to common/spl/Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-06socfpga: add support for Terasic DE1-SoC boardAnatolij Gustschin
Add CycloneV based Terasic DE1-SoC board. The board boots from SD/MMC. Ethernet and USB host is supported. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Marek Vasut <marex@denx.de>
