CONFIG_SPL_STACK
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SYS_MAXARGS
CONFIG_CLOCKS
CONFIG_TIMESTAMP
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Prepare v2021.07-rc5
# gpg: Signature made Mon 28 Jun 2021 03:39:36 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# configs/am64x_evm_r5_defconfig
CONFIG_SYS_DFU_MAX_FILE_SIZE to Kconfig
Currently the config options CONFIG_SYS_DFU_DATA_BUF_SIZE and
CONFIG_SYS_DFU_MAX_FILE_SIZE are being set in include/configs/<board>.h
files and also in <board_name>_defconfig files without a Kconfig option. It
is easier for users to set these configs in defconfig files than in config
header files as they are a part of the source code.
Add Kconfig symbols, and update the defconfigs by using tools/moveconfig.py
script.
Suggested-by: Pratyush Yadav <p.yadav@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Acked-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Acked-by: Matthias Brugger <mbrugger@suse.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Merge all outstanding changes from the current next branch in now that
we have released.
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
- Assorted fixes
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
The default mtdparts value grew a trailing zero during the Kconfig
conversion. This is because the mtdparts value in the header file
had a \0 at the end, which got misconverted into plain 0 instead of
being dropped.
Fixes: 43ede0bca7fc ("Kconfig: Migrate MTDIDS_DEFAULT / MTDPARTS_DEFAULT")
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Most boards currently use SPI_FLASH_MTD only in U-Boot proper, not in
SPL. They often rely on hacks in the board header files to include
this option conditionally. To be able to fix this, we previously
introduced a separate option SPL_SPI_FLASH_MTD.
Therefore we can now adjust the Makefile and change the code in
sf_probe.c and sf_internal.h to use CONFIG_IS_ENABLED(SPI_FLASH_MTD).
We also need to move all occurences of CONFIG_SPI_FLASH_MTD from the
header files to the according defconfigs. The affected boards are
socfpga, aristainetos, cm_fx6, display5, ventana, rcar-gen2, dh_imx6
and da850evm.
We do this all in one patch to guarantee bisectibility.
This change was tested with buildman to make sure it does not
introduce any regressions by comparing the resulting binary sizes.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
These boards don't have a watchdog enabled in SPL, so make sure
CONFIG_SPL_WDT is not enabled.
Fixes: commit 6874cb72204f ("watchdog: Split WDT from SPL_WDT")
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
[trini: Re-run migration]
This commit moves common config options used in all socfpga boards
to select/imply in Kconfig. This both cleans up the defconfig files
as well as makes future changes easier.
Options implied/defaulted for all sub-arches:
- SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS
Options implied/defaulted for implied for A10 & gen5:
- FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE
Options implied/defaulted for gen5:
- SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
None of the SoCFPGA platforms will support EFI/ISO partition types that
is needed for DISTRO_DEFAULTS. SoCFPGA bootroom will only support 0xa2
partition type.
This is needed to help limit the size of the SPL to within the 64k limit
that is required for SoCFPGA.
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
Add the DM reset driver to socfpga defconfigs.
Enable DM I2C driver on SoCFPGA platforms.
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
A number of platforms include config_distro_defaults.h but do not enable
CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and
re-sync config files.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
