path: root/configs/socfpga_de0_nano_soc_defconfig
2019-04-25arm: socfpga: imply/default common config optionsSimon Goldschmidt
This commit moves common config options used in all socfpga boards to select/imply in Kconfig. This both cleans up the defconfig files as well as makes future changes easier. Options implied/defaulted for all sub-arches: - SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS Options implied/defaulted for implied for A10 & gen5: - FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE Options implied/defaulted for gen5: - SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-28configs: Resync with savedefconfigTom Rini
2018-04-17configs: socfpga: disable EFI and ISO partition typesDinh Nguyen
None of the SoCFPGA platforms will support EFI/ISO partition types that is needed for DISTRO_DEFAULTS. SoCFPGA bootroom will only support 0xa2 partition type. This is needed to help limit the size of the SPL to within the 64k limit that is required for SoCFPGA. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-17configs: socfpga: add DM_RESETDinh Nguyen
Add the DM reset driver to socfpga defconfigs. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-17configs: socfpga: convert i2c to dmDinh Nguyen
Enable DM I2C driver on SoCFPGA platforms. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-25arm: socfpga: allow configs without network supportSimon Goldschmidt
Currently, socfpga_common.h does not allow configurations without network support. This is because CONFIG_CMD_PXE is defined in this file and distro mode has DHCP hard-coded as available. Fix this by moving CONFIG_CMD_PXE and CONFIG_MENU to the defconfigs and by making DHCP optional in BOOT_TARGET_DEVICES(func). Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-01-09ARM: socfpga: Enable part command for socfpga platformAndrey Zhizhikin
Enable CONFIG_CMD_PART item, as default environment requires it and complains this command in unknown. Signed-off-by: Andrey Zhizhikin <andrey.z@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-23arm: socfpga: Configuration for EFI boot on DE0-nano-SoCFrank Kunz
For EFI boot GPT partition table support is needed as well as the part command and also the SPL needs to fallback to other boot methods after parse the SPL header. Signed-off-by: Frank Kunz <mailinglists@kunz-im-inter.net>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-07-26kconfig: Convert FPGA_SOCFPGA configuration to KconfigTien Fong Chee
This converts the following to Kconfig: CONFIG_FPGA_SOCFPGA Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-04-14arm: socfpga: DE0 use environment in common headerDalon Westergreen
This removes the default environment from the de0 headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot. In addition to the above, add support to boot from the custom a2 type partition Signed-off-by: Dalon Westergreen <dwesterg@gmail.com> Acked-by: Marek Vasut <marex@denx.de> -- Changes in v2: - Remove unneeded CONFIG_BOOTFILE
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-07ARM: socfpga: use the default CONFIG_BOOTDELAY=2Masahiro Yamada
This option controls how long it should be paused before entering the auto-boot mode. The default value from Kconfig should be fine except socfpga_vining_fpga_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-01arm: socfpga: Enable tiny printf and simple malloc in SPLMarek Vasut
Enable both features to reduce the SPL size by 6 kiB. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de>
