path: root/configs/socfpga_dbm_soc1_defconfig
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-10-25mtd: spi: Clean up usage of CONFIG_SPI_FLASH_MTDFrieder Schrempf
Most boards currently use SPI_FLASH_MTD only in U-Boot proper, not in SPL. They often rely on hacks in the board header files to include this option conditionally. To be able to fix this, we previously introduced a separate option SPL_SPI_FLASH_MTD. Therefore we can now adjust the Makefile and change the code in sf_probe.c and sf_internal.h to use CONFIG_IS_ENABLED(SPI_FLASH_MTD). We also need to move all occurences of CONFIG_SPI_FLASH_MTD from the header files to the according defconfigs. The affected boards are socfpga, aristainetos, cm_fx6, display5, ventana, rcar-gen2, dh_imx6 and da850evm. We do this all in one patch to guarantee bisectibility. This change was tested with buildman to make sure it does not introduce any regressions by comparing the resulting binary sizes. Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-10-06arm: socfpga: disable CONFIG_SPL_WDT for gen5 and a10Simon Goldschmidt
These boards don't have a watchdog enabled in SPL, so make sure CONFIG_SPL_WDT is not enabled. Fixes: commit 6874cb72204f ("watchdog: Split WDT from SPL_WDT") Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-04-25arm: socfpga: imply/default common config optionsSimon Goldschmidt
This commit moves common config options used in all socfpga boards to select/imply in Kconfig. This both cleans up the defconfig files as well as makes future changes easier. Options implied/defaulted for all sub-arches: - SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS Options implied/defaulted for implied for A10 & gen5: - FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE Options implied/defaulted for gen5: - SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-28configs: Resync with savedefconfigTom Rini
2018-04-17Merge git://git.denx.de/u-boot-socfpgaTom Rini
2018-04-17configs: socfpga: disable EFI and ISO partition typesDinh Nguyen
None of the SoCFPGA platforms will support EFI/ISO partition types that is needed for DISTRO_DEFAULTS. SoCFPGA bootroom will only support 0xa2 partition type. This is needed to help limit the size of the SPL to within the 64k limit that is required for SoCFPGA. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-17configs: socfpga: add DM_RESETDinh Nguyen
Add the DM reset driver to socfpga defconfigs. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-17configs: socfpga: convert i2c to dmDinh Nguyen
Enable DM I2C driver on SoCFPGA platforms. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-26ARM: socfpga: Add new CycloneV SoC Devboards DBM-SoC1 boardMarek Vasut
Add support for a new boards from devboards.de , the DBM-SoC1 . This board has one ethernet port, one USB OTG port and USB UART. Signed-off-by: Marek Vasut <marex@denx.de>
