path: root/configs/socfpga_cyclone5_defconfig
2016-06-01arm: socfpga: Enable tiny printf and simple malloc in SPLMarek Vasut
Enable both features to reduce the SPL size by 6 kiB. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de>
2016-05-17i2c: config: Move SYS_I2C_DW to KconfigStefan Roese
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config header to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-10arm: socfpga: migration of CONFIG_SPI_FLASH_BARDenis Bakhvalov
CONFIG_SPI_FLASH_BAR was deleted from socfpga_common.h and placed in socfpga_*_defconfig because it is Kconfig symbol. Signed-off-by: Denis Bakhvalov <dendibakh@gmail.com> Reported-by: Denis Bakhvalov <dendibakh@gmail.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-13arm: socfpga: Enable SPL_DM_SEQ_ALIAS for all SOCFPGA configsNathan Rossi
This feature is required in SPL to enable support for loading from SPI flash. Also clean up the #define in socfpga_common.h. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin-Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-22arm: socfpga: cyclone5: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORSChin Liang See
Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS for UBI and UBIFS support on serial NOR flash Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-22arm: socfpga: Enable simple bus in SPL on all boardsMarek Vasut
The simple bus support must be enabled in SPL, otherwise the boards will not be able to parse the DT and will fail to boot. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: cyclone5-socdk: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-07arm: socfpga: Enable CONFIG_DM_MMCMarek Vasut
Enable driver model MMC support on SoCFPGA. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2015-08-23Merge git://git.denx.de/u-boot-socfpgaTom Rini
Conflicts: configs/socfpga_arria5_defconfig configs/socfpga_cyclone5_defconfig configs/socfpga_socrates_defconfig Merged these by hand and re-ran savedefconfig on them. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-23arm: socfpga: Enable DWAPB GPIO driverMarek Vasut
Enable the DWAPB GPIO driver for SoCFPGA Cyclone V and Arria V. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-08-23arm: socfpga: Unbind CPU type from board typeMarek Vasut
The CONFIG_TARGET_SOCFPGA_CYCLONE5 and CONFIG_TARGET_SOCFPGA_ARRIA5 selected both a board and a CPU. This is not correct as these macros are supposed to select only board. All would be good, if QTS-generated header files didn't check for these macros exactly to determine if the platform is Cyclone V or Arria V. Thus, for the sake of compatibility with not well fleshed out header file generator, this patch makes these two macros into a stub config option and introduces new CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK and CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK targets, which select the previous stub config option. The result is that compatibility with QTS is preserved and the new CONFIG_TARGET_* select actual target boards. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-18of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROLMasahiro Yamada
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-08arm: socfpga: config: Move SPL GD and malloc to RAMMarek Vasut
Now that the SPL structure is organised such that it matches the U-Boot's SPL design, it is possible to use the option of relocating GD to RAM. And since we have GD in RAM, move malloc area to RAM as well. We point the malloc base pointer 1 MiB past U-Boot's load address. We use simple malloc for SPL because it is 3kiB smaller in terms of code size than regular malloc which was used thus far. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-08arm: socfpga: misc: Probe ethernet GMAC from OFMarek Vasut
The GMAC can now be probed from OF, so enable DM ethernet and remove the old ad-hoc designware_initialize() invocation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2015-08-08arm: socfpga: spl: Add support for booting from QSPIMarek Vasut
Add code and configuration options to support booting from QSPI NOR. Enable support for booting from QSPI NOR. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-08arm: socfpga: spl: Add support for booting from SD/MMCMarek Vasut
Add code and configuration options to support booting from RAW SD/MMC card as well as for ext4/vfat filesystems. Enable support for booting from SD/MMC card, but don't enable the filesystem support just yet to retain compatibility with old SoCFPGA card format. Signed-off-by: Marek Vasut <marex@denx.de>
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-07ARM: socfpga: move board select into mach-socfpga/KconfigMasahiro Yamada
Switch to a more standard way of board select; put the SoC select into arch/arm/Kconfig and move the board select menu under arch/arm/mach-socfpga/Kconfig. Also, consolidate SYS_BOARD, SYS_VENDOR, SYS_SOC, SYS_CONFIG_NAME. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18ARM: socfpga: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-05arm: socfpga: Enable DM and DM_SPIMarek Vasut
Enable DM and DM_SPI support for both Cyclone 5 and Arria 5 boards, since they use drivers which require those. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Vince Bridgers <vbridger@opensource.altera.com>
2015-03-04dt: socfpga: Import and enable Cyclone V DK DTSMarek Vasut
Import DTS for Cyclone V development kit and enable support for DT. The DT is imported from Linux 3.19-rc1 as of commit 97bf6af1f928216fd6c5a66e8a57bfa95a659672 . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Vince Bridgers <vbridger@opensource.altera.com>
