Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind
several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently
not enough. Increase the default to 0x2000 for the case. This
will be helpful for shorter defconfigs.
This option controls how long it should be paused before entering
the auto-boot mode. The default value from Kconfig should be fine
except socfpga_vining_fpga_defconfig.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Enable both features to reduce the SPL size by 6 kiB.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Stefan Roese <sr@denx.de>
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config
header to the defconfig files.
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
CONFIG_SPI_FLASH_BAR was deleted from socfpga_common.h
and placed in socfpga_*_defconfig because it is Kconfig symbol.
Signed-off-by: Denis Bakhvalov <dendibakh@gmail.com>
Reported-by: Denis Bakhvalov <dendibakh@gmail.com>
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Various boards have the wrong Kconfig ordering now. To avoid a misleading
diff in the next patch, reorder the configuration correctly.
This feature is required in SPL to enable support for loading from SPI
flash.
Also clean up the #define in socfpga_common.h.
Signed-off-by: Nathan Rossi <nathan@nathanrossi.com>
Acked: Marek Vasut <marex@denx.de>
Cc: Chin-Liang See <clsee@altera.com>
Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS for UBI
and UBIFS support on serial NOR flash
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinh.linux@gmail.com>
The simple bus support must be enabled in SPL, otherwise the boards
will not be able to parse the DT and will fail to boot.
This patch adds the necessary OF alias for the UDC node, which let's
the code locate the DWC2 UDC base address in OF instead of hard-coding
it into the U-Boot binary. The code is adjusted to use the address from
OF instead of the hard-coded one. Finally, the hard-coded address is
removed and USB DM support is enabled.
Cc: Lukasz Majewski <l.majewski@majess.pl>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Enable driver model MMC support on SoCFPGA.
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Some boards' defconfigs are disordered. Reorder them.
configs/socfpga_arria5_defconfig
configs/socfpga_cyclone5_defconfig
configs/socfpga_socrates_defconfig
Merged these by hand and re-ran savedefconfig on them.
Enable the DWAPB GPIO driver for SoCFPGA Cyclone V and Arria V.
The CONFIG_TARGET_SOCFPGA_CYCLONE5 and CONFIG_TARGET_SOCFPGA_ARRIA5
selected both a board and a CPU. This is not correct as these macros
are supposed to select only board.
All would be good, if QTS-generated header files didn't check for
these macros exactly to determine if the platform is Cyclone V or
Arria V. Thus, for the sake of compatibility with not well fleshed
out header file generator, this patch makes these two macros into
a stub config option and introduces new CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK
and CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK targets, which select the
previous stub config option.
The result is that compatibility with QTS is preserved and the new
CONFIG_TARGET_* select actual target boards.
Several files are out of order. This means that when the moveconfig tool
moves CONFIG options to Kconfig it generates a large diff. To avoid this,
reorder the files first.
As we discussed a couple of times, negative CONFIG options make our
life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ...
and here is another one.
Now, there are three boards enabling OF_CONTROL on SPL:
- socfpga_arria5_defconfig
- socfpga_cyclone5_defconfig
- socfpga_socrates_defconfig
This commit adds CONFIG_SPL_OF_CONTROL for them and deletes
CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert
the logic.
Now that the SPL structure is organised such that it matches the
U-Boot's SPL design, it is possible to use the option of relocating
GD to RAM. And since we have GD in RAM, move malloc area to RAM as
well. We point the malloc base pointer 1 MiB past U-Boot's load
address. We use simple malloc for SPL because it is 3kiB smaller
in terms of code size than regular malloc which was used thus far.
The GMAC can now be probed from OF, so enable DM ethernet and remove the
old ad-hoc designware_initialize() invocation.
Add code and configuration options to support booting from QSPI NOR.
Enable support for booting from QSPI NOR.
Add code and configuration options to support booting from RAW
SD/MMC card as well as for ext4/vfat filesystems. Enable support
for booting from SD/MMC card, but don't enable the filesystem
support just yet to retain compatibility with old SoCFPGA card
format.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Having this as a Kconfig allows it to be a dependent feature.
Switch to a more standard way of board select; put the SoC select
into arch/arm/Kconfig and move the board select menu under
arch/arm/mach-socfpga/Kconfig.
Also, consolidate SYS_BOARD, SYS_VENDOR, SYS_SOC, SYS_CONFIG_NAME.
Move this to Kconfig and clean up board config files that use it. Also
rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists
in drivers/net/Kconfig.
Version 1:
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
Enable DM and DM_SPI support for both Cyclone 5 and Arria 5 boards,
since they use drivers which require those.
Cc: Chin Liang See <clsee@opensource.altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
Cc: Vince Bridgers <vbridger@opensource.altera.com>
Import DTS for Cyclone V development kit and enable support
for DT. The DT is imported from Linux 3.19-rc1 as of commit
97bf6af1f928216fd6c5a66e8a57bfa95a659672 .
