path: root/configs/socfpga_arria10_defconfig
2020-07-06Merge branch 'next'Tom Rini
Merge all outstanding changes from the current next branch in now that we have released.
2020-07-06configs: Resync with savedefconfigTom Rini
2020-06-26spi: Enable missing CONFIG_SPL_DM_SPI supportTom Rini
Due to how the Makefile logic is we currently get DM_SPI support in SPL enabled by having DM_SPI enabled for full U-Boot but not having CONFIG_SPL_DM_SPI set. Add this missing option to boards that were inadvertently making use of it. Cc: Adam Ford <aford173@gmail.com> Cc: Akash Gajjar <akash@openedev.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Andy Yan <andy.yan@rock-chips.com> Cc: Anup Patel <anup.patel@wdc.com> Cc: Atish Patra <atish.patra@wdc.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Chee Hong Ang <chee.hong.ang@intel.com> Cc: Chin-Liang See <clsee@altera.com> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Levin Du <djw@t-chip.com.cn> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Mike Looijmans <mike.looijmans@topic.nl> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Palmer Dabbelt <palmer@dabbelt.com> Cc: Patrick Delaunay <patrick.delaunay@st.com> Cc: Paul Walmsley <paul.walmsley@sifive.com> Cc: Pavel Machek <pavel@denx.de> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Suniel Mahesh <sunil@amarulasolutions.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Wolfgang Grandegger <wg@aries-embedded.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-04-27configs: socfpga: arria10: Enable USB supportLey Foon Tan
Enable configs to support USB in Arria 10. CONFIG_CMD_USB=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_DWC2=y Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-10-06arm: socfpga: disable CONFIG_SPL_WDT for gen5 and a10Simon Goldschmidt
These boards don't have a watchdog enabled in SPL, so make sure CONFIG_SPL_WDT is not enabled. Fixes: commit 6874cb72204f ("watchdog: Split WDT from SPL_WDT") Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-10ARM: socfpga: Synchronize the configuration for A10 SoCDKTien Fong Chee
Update the default configuration file to enable the necessary functionality the get the kit working. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2019-05-10ARM: socfpga: Add the configuration for FPGA SoCFPGA A10 SoCDKTien Fong Chee
Update the default configuration file to enable the necessary functionality to get the SoCFPGA loadfs driver support. This would enable the implementation of programming bitstream into FPGA from MMC. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2019-04-25arm: socfpga: imply/default common config optionsSimon Goldschmidt
This commit moves common config options used in all socfpga boards to select/imply in Kconfig. This both cleans up the defconfig files as well as makes future changes easier. Options implied/defaulted for all sub-arches: - SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS Options implied/defaulted for implied for A10 & gen5: - FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE Options implied/defaulted for gen5: - SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-11-13configs: Resync with savedefconfigTom Rini
2018-08-24ARM: socfpga: Convert Arria10 to timer frameworkMarek Vasut
Switch the Arria10 from ad-hoc hardcoded timer to timer framework and the DW APB timer driver. This allows the A10 to extract timer information, like timer rate, from clock framework and thus DT instead of having it hardcoded in U-Boot configuration files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-08-17Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2018-08-13ARM: socfpga: Enable DM ethernet on A10Marek Vasut
Enable DM ethernet framework on Arria10, so that the designware GMAC can be probed from DT as it should be. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Ley Foon Tan <ley.foon.tan@intel.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-28configs: Resync with savedefconfigTom Rini
2018-04-17configs: socfpga: disable EFI and ISO partition typesDinh Nguyen
None of the SoCFPGA platforms will support EFI/ISO partition types that is needed for DISTRO_DEFAULTS. SoCFPGA bootroom will only support 0xa2 partition type. This is needed to help limit the size of the SPL to within the 64k limit that is required for SoCFPGA. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-25arm: socfpga: allow configs without network supportSimon Goldschmidt
Currently, socfpga_common.h does not allow configurations without network support. This is because CONFIG_CMD_PXE is defined in this file and distro mode has DHCP hard-coded as available. Fix this by moving CONFIG_CMD_PXE and CONFIG_MENU to the defconfigs and by making DHCP optional in BOOT_TARGET_DEVICES(func). Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-01-09ARM: socfpga: Enable part command for socfpga platformAndrey Zhizhikin
Enable CONFIG_CMD_PART item, as default environment requires it and complains this command in unknown. Signed-off-by: Andrey Zhizhikin <andrey.z@gmail.com>
2017-07-26configs: Add FPGA driver config for Arria 10Tien Fong Chee
Add FPGA driver config for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-05-18arm: socfpga: Add config and defconfig for Arria 10Ley Foon Tan
Add config and defconfig for the Arria10 and update socfpga_common.h. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
