path: root/configs/snow_defconfig
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: exynos: Move CONFIG_SOUND_WM8994 to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: exynos: Move CONFIG_SOUND_MAX98095 to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_I2S_SAMSUNG to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_I2S to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_CMD_SOUND to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_SOUND to KconfigSimon Glass
2015-04-18cros_ec: Drop unused CONFIG_DM_CROS_ECSimon Glass
Since all supported boards enable this option now, we can remove it along with the old code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-19dm: cros_ec: Convert to KconfigSimon Glass
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses. LPC will need to wait until driver mode PCI is available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-08-30exynos: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Exynos board select menu to exynos/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="exynos"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
