path: root/configs/smdkc100_defconfig
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-28malloc_f: remove redundant defalut values of CONFIG_SYS_MALLOC_F_LENMasahiro Yamada
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig as 0x400. Each defconfig or Kconfig need not repeat the same value. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-08samsung: Enable device tree for smdkc100Simon Glass
Change this board to add a device tree. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
