path: root/configs/smartweb_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28Convert CONFIG_SPL_NAND_BASE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_NAND_BASE CONFIG_SPL_NAND_IDENT Signed-off-by: Adam Ford <aford173@gmail.com>
2020-07-28Convert CONFIG_SPL_NAND_DRIVERS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SPL_NAND_DRIVERS CONFIG_SPL_NAND_ECC CONFIG_SPL_NAND_SIMPLE Signed-off-by: Adam Ford <aford173@gmail.com>
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-06-26Convert CONFIG_ATMEL_USART to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ATMEL_USART Signed-off-by: Tom Rini <trini@konsulko.com>
2020-06-26Convert CONFIG_AT91_GPIO to KconfigTom Rini
This converts the following to Kconfig: CONFIG_AT91_GPIO Signed-off-by: Tom Rini <trini@konsulko.com>
2020-02-28configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when CMD_MTDPARTS is selectedMiquel Raynal
MTD support must be enabled when using mtdparts. Indeed, functions like get_mtd_info(), get_mtd_device() and put_mtd_device() are in drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-21configs: Resync with savedefconfigTom Rini
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-09at91, omap2plus: configs: migrate CONFIG_ENV_ to defconfigsMarkus Klotzbuecher
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be able to use CONFIG_ENV_UBI_* on these architectures. As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE, ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to KConfig. This migration was run using an extended moveconfig.py which evaluates expressions such as "(512 << 10)". See patch ("moveconfig: expand simple expressions"). All modified boards were built with SOURCE_DATE_EPOCH=0 before and after the change and successfully confirmed that the identical binary is generated (the only exception was igep00x0, which does not define CONFIG_ENV_IS_IN_UBI in the original board header. Once that is defined, the test passes too). hs: rebased patch to: 68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT" Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-09arm: at91: Remove CONFIG_AT91_HW_WDT_TIMEOUTStefan Roese
This patch removes the CONFIG_AT91_HW_WDT_TIMEOUT as its not needed any more. The WD timeout value can be provided via the "timeout-sec" DT property. If not provided this way, the default value of 2 seconds will be used. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-16arm: at91: wdt: Convert watchdog driver to dm/dtPrasanthi Chellakumar
Convert the Watchdog driver for AT91SAM9x processors to support the driver model and device tree. Changes "CONFIG_AT91SAM9_WATCHDOG" to new "CONFIG_WDT_AT91" Kconfig option. Signed-off-by: Prasanthi Chellakumar <prasanthi.chellakumar@microchip.com>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21smartweb: use SPL_TINY_MEMSETPhilipp Tomsich
The SPL code for smartweb is close to its limit and adding a few extra instructions to SPL will cause it to overrun its sram allotement (thus causing build failures). To allow adding the 'spl_perform_fixups' extension point to SPL, we'll enable SPL_TINY_MEMSET for smartweb. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Series-cc: trini
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-11at91, smartweb: use SPL_SYS_MALLOC_F_LENHeiko Schocher
commit f1896c45cb2f: spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LEN introduced independent SYS_MALLOC_F_LEN for SPL and U-Boot. Use it on the smartweb board, as above commit broke the smartweb board. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-29atmel, at91: fix smartweb boardHeiko Schocher
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support" smartweb board comes not up anymore. Fix it. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
