path: root/configs/smartweb_defconfig
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-11at91, smartweb: use SPL_SYS_MALLOC_F_LENHeiko Schocher
commit f1896c45cb2f: spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LEN introduced independent SYS_MALLOC_F_LEN for SPL and U-Boot. Use it on the smartweb board, as above commit broke the smartweb board. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-29atmel, at91: fix smartweb boardHeiko Schocher
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support" smartweb board comes not up anymore. Fix it. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-01-20ARM: Default to using optimized memset and memcpy routinesTom Rini
We have long had available optimized versions of the memset and memcpy functions that are borrowed from the Linux kernel. We should use these in normal conditions as the speed wins in many workflows outweigh the relatively minor size increase. However, we have a number of places where we're simply too close to size limits in SPL and must be able to make the size vs performance trade-off in those cases. Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: Heiko Schocher <hs@denx.de> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-20configs: Re-syncTom Rini
2016-06-26arm: at91: smartweb: add DM and DTS supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [rebased on current ToT] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-18siemens,at91: enable features for smartwebMatthias Michel
New features for smartweb: * switch to hush command parser * change autoboot stop to <ESC><ESC> * allow to write ethaddr Signed-off-by: Matthias Michel <matthias.michel@siemens.com> Reviewed-by: Samuel Egli <samuel.egli@siemens.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-12arm, at91: support for sam9260 based smartweb boardHeiko Schocher
add support for the at91sam9260 based board smartweb from siemens. SPL is used without serial support, as this SoC has only 4k sram for running SPL. Here a U-Boot bootlog: RomBOOT > U-Boot 2015.07-rc2-00109-g4ae828c (Jun 15 2015 - 09:31:16 +0200) CPU: AT91SAM9260 Crystal frequency: 18.432 MHz CPU clock : 198.656 MHz Master clock : 99.328 MHz Watchdog enabled DRAM: 64 MiB WARNING: Caches not enabled NAND: 256 MiB In: serial Out: serial Err: serial Net: macb0 Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Heiko Schocher <hs@denx.de>
