path: root/configs/sksimx6_defconfig
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-12mx6: Support SKS-Kinkel sksimx6 BoardStefano Babic
Board has 1GB RAM and boots from SD Card U-Boot SPL 2018.01-rc3-00005-ga1898b8 (Jan 02 2018 - 13:48:54) BT_FUSE_SEL already fused, will do nothing Trying to boot from MMC1 U-Boot 2018.01-rc3-00005-ga1898b8 (Jan 02 2018 - 13:48:54 +0100) CPU: Freescale i.MX6DL rev1.2 996 MHz (running at 792 MHz) CPU: Commercial temperature grade (0C to 95C) at 40C Reset cause: POR I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC [PRIME] Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
