them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This adds GPIO configuration and initialization function of SDHI on Silk board
Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com>
This adds drivers model support of serial port to Silk board,
and migrate serial port to drivers model.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
SILK is an entry level development board based on R-Car E2 SoC (R8A7794)
This commit supports the following peripherals:
- SCIF, I2C, Ethernet, QSPI, MMC, USB Host
Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com>
Reviewed-by: Tom Rini <trini@ti.com>
