path: root/configs/silk_defconfig
2016-08-17arm: rmobile: Update defconfigNobuhiro Iwamatsu
This updated defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-04-18ARM: rmobile: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-25arm: rmobile: silk: Add support SDHIVladimir Barinov
This adds GPIO configuration and initialization function of SDHI on Silk board Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Silk board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-13arm: rmobile: Add SILK board supportVladimir Barinov
SILK is an entry level development board based on R-Car E2 SoC (R8A7794) This commit supports the following peripherals: - SCIF, I2C, Ethernet, QSPI, MMC, USB Host Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Reviewed-by: Tom Rini <trini@ti.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
