path: root/configs/shmin_defconfig
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
