path: root/configs/sheep-rk3368_defconfig
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-18rockchip: rk3368: add the missing target and pinctrl config for sheep boardAndy Yan
Add the missing target and pinctrl config for rk3368 sheep board Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-09-08configs: Resync with savedefconfigTom Rini
2017-08-13rockchip: set Pre-reloc malloc pool size to 4kb for rk3368 based boardsAndy Yan
The default 1kb pre-reloc malloc pool is not enough for dm core to enable the dm-pre-reloc device drivers. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: rk3368: add Sheep boardAndy Yan
Sheep board is designed by Rockchip as a EVB for rk3368. Currently it is able to boot a linux kernel and system to console with the miniloader run as fist level loader. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
