path: root/configs/sh7763rdp_defconfig
2017-08-11Convert CONFIG_CMD_SDRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SDRAM Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
