path: root/configs/sh7757lcr_defconfig
2014-11-17sh: Move SH_32BIT to KconfigNobuhiro Iwamatsu
This moves SH_32BIT to Kconfig, and removes SH_32BIT from config files. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
