path: root/configs/sfr_nb4-ser_ram_defconfig
2017-05-10mips: bmips: enable bcm6345-reset driver for all BMIPS boardsÁlvaro Fernández Rojas
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-10mips: bmips: enable bcm6345-clk driver for all BMIPS boardsÁlvaro Fernández Rojas
2017-05-10mips: bmips: add NeufBox 4 (Sercomm) boardÁlvaro Fernández Rojas
This serves as an example for bcm6358-leds. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
