path: root/configs/sei610_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-10-24configs: sei610: khadas-vim3 : disable Gadget support for the DWC3Jean-Jacques Hiblot
Those platform use the DWC2 controller for the gadget support and the DWC3 for host-only operations. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-10-18configs: sei610: Add config file to fix userdata sizeGuillaume La Roque
Add separate config file to handle the different eMMC size on the sei610 board. Signed-off-by: Guillaume La Roque <glaroque@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-10-18boards: amlogic: add SEI610 supportNeil Armstrong
Add support for the customer board SEI610 manufactured by SEI Robotics with the following specifications: - Amlogic S905X3 ARM Cortex-A55 quad-core SoC - 2GB DDR4 SDRAM - 10/100 Ethernet (Internal PHY) - 1 x USB 3.0 Host - 1 x USB Type-C DRD - 1 x FTDI USB Serial Debug Interface - eMMC - SDcard - Infrared receiver - SDIO WiFi Module Like it's SEI510 counterpart, the boot flow is designed to boot Android AOSP built for the Yukawa Android device. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
