CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
Activate the following Kconfig options:
* AVB for Android Verified Boot support
* ADTIMG for merging DTBOs
* ABOOTIMG for extracting Android boot image
Also rework the partitioning tables:
- add a misc partition to handle BCB messages
- add a dtbo partition to store various DTBOs
- add a vbmeta partition for AVB hashes
- Merge vendor and system into the "super" partition
Note: avb support is disables by default. To activate it:
=> setenv force_avb 1;
=> saveenv;
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
SEI-610 and SEI-510 are both for Android boards based on Yukawa[1]
Enable the BCB command to enable the standard Android boot flow.
[1] https://android.googlesource.com/device/amlogic/yukawa/
Use the proper Synopsys DWMAC Meson8b glue to handle the ethernet link type.
Use DM_MDIO and the new G12A MDIO MUX driver for G12A, G12B & SM1 boards.
Done with:
./tools/moveconfig.py BMP_16BPP BMP_24BPP BMP_32BPP
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
The mode selection for the DWC3 is kind of obsolete. The driver does not
have to be host only or gadget only. This choice is confusing.
All the remaining callers of dwc3_uboot_init() explicitly set dr_mode
before calling the function, so none rely on a default behavior.
Remove the choice menu and keep only the USB_DWC3_GADGET option. Enable it
by default if USB_GADGET and USB_DWC3 are enabled.
It must be disabled for the evb-rk3328 as it uses DWC2 for the gadget and
DWC3 for the host.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
The GX VPU Power Domain driver has been replaced by the Everything-Else
Power Domain driver for G12A and SM1.
Add the necessary config options to support BMP display over HDMI,
and add a preboot command to load the BMP file from a predefined
eMMC partition.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Disable the PSCI_RESET reboot handler to permit handling the reboot
flag and calling the PSCI handler with the flag in parameter.
The SEI510 board is based on the Amlogic S905X2 SoC
from the Amlogic G12A SoC family.
The board has the following specifications :
- Amlogic S905X2 ARM Cortex-A53 quad-core SoC
- XGB DDR4 SDRAM
- 10/100 Ethernet (Internal PHY)
- 1 x USB 3.0 Host
- eMMC
- SDcard
- Infrared receiver
- SDIO WiFi Module
The board default behaviour is for booting Android and triggers
fastboot on recovery or reboot mode.
USB vendor ID (used by fastboot) is 0x18d1 (Google) for
default udev rules for existing android users work out of the box.
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
