This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Some boards' defconfigs are disordered. Reorder them.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Add basic SECO MX6Q/uQ7 board support (Ethernet, UART, SD are supported).
It also adds a Kconfig skeleton to later add more SECO board (supporting
SoC and board variants).
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
