path: root/configs/sbc8548_PCI_66_defconfig
2017-05-22Convert CONFIG_CMD_IRQ to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IRQ Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
