Add test for the erase command tested on ENV in EXT4.
Add support of environment location with the new env command:
'env select' and 'env load'
The ENV backend is selected by priority order
- 0 = "nowhere" (default at boot)
- 1 = "EXT4"
To test EXT4 env support, this backend is selected by name:
> env select EXT4
Activate ENV in EXT4 support in sandbox.
The sandbox behavior don't change; the default environment with
the nowhere backend (CONFIG_ENV_IS_NOWHERE)is still used:
the weak function env_get_location() return ENVL_NOWHERE for priority 0.
At present we use the empty string to indicate that there is no FIT
generator, but this doesn't allow an individual board to undefine it.
Create a separate bool instead.
Update the config of the boards which currently have an empty string.
CONFIG_BOOTP_SEND_HOSTNAME
https://gitlab.denx.de/u-boot/custodians/u-boot-dm
binman support for FIT
new UCLASS_SOC
patman switch 'test' command
minor fdt fixes
patman usability improvements
Enable support for sub command 'env info' in sandbox
with CONFIG_CMD_NVEDIT_INFO. This is aimed primarily
at adding unit test.
Add a sandbox SOC driver, and some tests for the SOC uclass.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing
changes made to 56d37f1c564107e27d873181d838571b7d7860e7.
Unfortunately this is causing CI failures:
https://travis-ci.org/github/trini/u-boot/jobs/711313649
Merge all outstanding changes from the current next branch in now that
we have released.
currently gpio hog function is not tested with "ut dm gpio"
so add some basic tests for gpio hog functionality.
For this enable GPIO_HOG in sandbox_defconfig, add
in DTS some gpio hog entries, and add testcase in
"ut dm gpio" command.
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
As we discussed in [1], this option is not needed for sandbox build.
[1] https://lists.denx.de/pipermail/u-boot/2020-February/400182.html
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
'bootefi hello' is used in one of the Python tests.
efidebug can be used to verify the correct initialization of the UEFI
sub-system.
Reviewed-by: Simon Glass <sjg@chromum.org>
We want to always run RSA library test on sandbox build in Travis CI.
Just adding CONFIG_RSA_VERIFY_WITH_PKEY would be good enough for this
purpose.
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Add a simple sandbox test for this uclass.
Add a sandbox driver and PCI-device emulator for p2sb. Also add a test
which uses a simple 'adder' driver to test the p2sb functionality.
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Enable the support of function keys on the USB keyboard. This is necessary
to test the USB keyboard driver.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
At present there is only one control for this and it is used for both SPL
and TPL. But SPL might have a lot more space than TPL so the extra cost of
a full printf() might be acceptable.
Split the option into two, providing separate SPL and TPL controls. The
TPL setting defaults to the same as SPL.
- More DaVinci DM migration, drop am18xx EVM platform
- Keystone bug fix
There are no more "real" users of CONFIG_DM_I2C_COMPAT and we'll soon
remove it altogether. Stop building it in sandbox mode.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Acked-by: Heiko Schocher <hs@denx.de>
This adds separate kconfig options for drivers/sysreset and
drivers/firmware.
Up to now, CONFIG_SPL_DRIVERS_MISC_SUPPORT added drivers/misc to SPL
build but also added drivers/firmware and drivers/sysreset at the same
time.
Since that is confusing, this patch uses CONFIG_SPL_SYSRESET for
drivers/sysreset and adds CONFIG_SPL_FIRMWARE for
drivers/firmware (and accordingly for the TPL options).
CONFIG_SPL_DRIVERS_MISC_SUPPORT stays for including drivers/misc into
the SPL build (and accordingly for TPL) since there are boards using
non-DM (non UCLASS_MISC) files from drivers/misc. Such boards don't
have CONFIG_SPL_MISC enabled, so cannot use this to include
drivers/misc into the SPL build.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
The USE_TINY_PRINTF symbol only changes things within SPL and TPL
builds, so make it depend on that support. Next, make it default as
within these cases we should rarely have need of more advanced print
formats outside of the debug context.
To do this, in a few cases we need to correct our Kconfig dependencies
as we had cases of non-SPL targets select'ing this symbol. Finally, in
the case of a few boards we really do need the full printf
functionality.
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers
and whitelist. This patch is a follow-up on a patch by Christian
Gmeiner with the added config/header/whitelist updates.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com>
SPL/TPL also need use sysreset for some feature like panic callback.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
This is close to full now, so increase it to avoid problems with adding
more devices.
There is some basic informaton that SPL normally wants to pass through to
U-Boot, such as the SDRAM size and bank information.
Mkae use of the new bloblist structure for this. Add a new 'handoff' blob
which is set up in SPL and passed to U-Boot proper. Also adda test for
sandbox_spl that checks that this works correctly and a new 'sb' command
to show the information passed from SPL.
Add tests for the new board uclass.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Add sandbox driver and tests for the new OSD uclass.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
