path: root/configs/sandbox_spl_defconfig
2019-05-08sysreset: enable driver support in SPL/TPLKever Yang
SPL/TPL also need use sysreset for some feature like panic callback. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-13sandbox: Increase the pre-relocation memorySimon Glass
This is close to full now, so increase it to avoid problems with adding more devices. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26spl: Add support for passing handoff info to U-Boot properSimon Glass
There is some basic informaton that SPL normally wants to pass through to U-Boot, such as the SDRAM size and bank information. Mkae use of the new bloblist structure for this. Add a new 'handoff' blob which is set up in SPL and passed to U-Boot proper. Also adda test for sandbox_spl that checks that this works correctly and a new 'sb' command to show the information passed from SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-09-30Merge git://git.denx.de/u-boot-dmTom Rini
2018-09-29test: Add tests for board uclassMario Six
Add tests for the new board uclass. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-28video_osd: Add osd sandbox driver and testsMario Six
Add sandbox driver and tests for the new OSD uclass. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-05-25configs: add TPMv2.x support in SandboxMiquel Raynal
Enable the Sandbox TPMv2 driver in all possible configurations. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-18sandbox: Enable MC34708 PMIC supportLukasz Majewski
This MC34708 PMIC is somewhat special - it used single transfers (R/W) with 3 bytes size - up till now U-Boot's PMICs only used 1 byte. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-27usb: kbd: Set a default polling mechanism for USB keyboardBin Meng
The choice of "USB keyboard polling" cannot be optional as without one mechanism being set, it just doesn't work. Set the default one to CONFIG_SYS_USB_EVENT_POLL. Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-16bootstage: Drop unused optionsSimon Glass
The CONFIG_BOOTSTAGE_USER_COUNT option is no-longer needed since we can now support any number of user IDs. Also BOOTSTAGE_ID_COUNT is not needed now. Drop these unused options. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-28sandbox: Enable NVMe driver for build testingBin Meng
This enables NVMe driver on sandbox for build testing. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-06-05bootstage: Change CONFIG_BOOTSTAGE_USER_COUNT to an intSimon Glass
There is no good read to make this hex, and integer is more natural for this type of setting. Update it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_FLAGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_FLAGS Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_CALLBACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_CALLBACK Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-09dm: test: Add tests for the generic PHY uclassJean-Jacques Hiblot
Those tests check: - the ability for a phy-user to get a phy based on its name or its index - the ability of a phy device (provider) to manage multiple ports - the ability to perform operations on the phy (init,deinit,on,off) - the behavior of the uclass when optional operations are not implemented Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-30fs: Kconfig: Add a separate option for FS_CRAMFSSimon Glass
Rather than using CMD_CRAMFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CRAMFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CRAMFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CRAMFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Kconfig: Add a separate config for FS_CBFSSimon Glass
Rather than using CMD_CBFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CBFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CBFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CBFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27dm: sandbox: pwm: Add a basic pwm testSimon Glass
Unfortunately a test for the PWM uclass was not included when it was submitted. This was noticed when trying to add more functionality: http://patchwork.ozlabs.org/patch/748172/ Add a simple test to get us started. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-14dm: led: Add support for blinking LEDsSimon Glass
Allow LEDs to be blinked if the driver supports it. Enable this for sandbox so that the tests run. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Ziping Chen <techping.chan@gmail.com>
2017-03-17configs: move CMD_MD5SUM definition to defconfigsAndre Przywara
Boards with an apparent need for the md5sum command had the connected config symbol defined in their board header file. Move this over to the respective defconfig files now that md5sum is configured via Kconfig. (This is a manual effort, which differs from moveconfig.py, not sure who is right here. Boards except sandbox loose the md5sum command with moveconfig.py, though it was explicitly mentioned in their config.h's) Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: migrate stih410-b2260] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: sandbox: rename CONFIG, fix dependency, and use it in MakefileMasahiro Yamada
[1] Rename CONFIG_SANDBOX_MMC to CONFIG_MMC_SANDBOX for consistency I want all MMC driver options prefixed with CONFIG_MMC_. [2] Fix dependency Add necessary depends on to avoid compile error. Instead "depends on MMC" is unneeded because this config entry resides inside of "if MMC". [3] Currently, this config symbol is not referenced at all. Use it to enable/disable the driver in Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-28disk: convert CONFIG_AMIGA_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
