path: root/configs/sandbox_spl_defconfig
2017-06-05bootstage: Change CONFIG_BOOTSTAGE_USER_COUNT to an intSimon Glass
There is no good read to make this hex, and integer is more natural for this type of setting. Update it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_FLAGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_FLAGS Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_CALLBACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_CALLBACK Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-09dm: test: Add tests for the generic PHY uclassJean-Jacques Hiblot
Those tests check: - the ability for a phy-user to get a phy based on its name or its index - the ability of a phy device (provider) to manage multiple ports - the ability to perform operations on the phy (init,deinit,on,off) - the behavior of the uclass when optional operations are not implemented Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-30fs: Kconfig: Add a separate option for FS_CRAMFSSimon Glass
Rather than using CMD_CRAMFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CRAMFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CRAMFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CRAMFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Kconfig: Add a separate config for FS_CBFSSimon Glass
Rather than using CMD_CBFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CBFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CBFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CBFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27dm: sandbox: pwm: Add a basic pwm testSimon Glass
Unfortunately a test for the PWM uclass was not included when it was submitted. This was noticed when trying to add more functionality: http://patchwork.ozlabs.org/patch/748172/ Add a simple test to get us started. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-14dm: led: Add support for blinking LEDsSimon Glass
Allow LEDs to be blinked if the driver supports it. Enable this for sandbox so that the tests run. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Ziping Chen <techping.chan@gmail.com>
2017-03-17configs: move CMD_MD5SUM definition to defconfigsAndre Przywara
Boards with an apparent need for the md5sum command had the connected config symbol defined in their board header file. Move this over to the respective defconfig files now that md5sum is configured via Kconfig. (This is a manual effort, which differs from moveconfig.py, not sure who is right here. Boards except sandbox loose the md5sum command with moveconfig.py, though it was explicitly mentioned in their config.h's) Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: migrate stih410-b2260] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: sandbox: rename CONFIG, fix dependency, and use it in MakefileMasahiro Yamada
[1] Rename CONFIG_SANDBOX_MMC to CONFIG_MMC_SANDBOX for consistency I want all MMC driver options prefixed with CONFIG_MMC_. [2] Fix dependency Add necessary depends on to avoid compile error. Instead "depends on MMC" is unneeded because this config entry resides inside of "if MMC". [3] Currently, this config symbol is not referenced at all. Use it to enable/disable the driver in Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-28disk: convert CONFIG_AMIGA_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: sandbox: Enable of-platdata for sandbox_splSimon Glass
Enable this feature so that we can use it for testing in sandbox_spl. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14sandbox: Add a new sandbox_spl boardSimon Glass
It is useful to be able to build SPL for sandbox. It provides additional build coverage and allows SPL features to be tested in sandbox. However it does not need worthwhile to always create an SPL build. It nearly doubles the build time and the feature is (so far) seldom used. So for now, create a separate build target for sandbox SPL. This allows experimentation with this new feature without impacting existing workflows. Signed-off-by: Simon Glass <sjg@chromium.org>
