- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
This enables NVMe driver on sandbox for build testing.
CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
There is no good read to make this hex, and integer is more natural for
this type of setting. Update it.
CONFIG_CMD_IDE
CONFIG_CMD_ENV_FLAGS
CONFIG_CMD_ENV_CALLBACK
CONFIG_SPL_BOARD_INIT
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
[trini: Update the Kconfig logic]
Since this driver can be used for rk8xx series pmic,
let's rename rk808 to rk8xx, to make it clear.
Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./`
Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
Those tests check:
- the ability for a phy-user to get a phy based on its name or its index
- the ability of a phy device (provider) to manage multiple ports
- the ability to perform operations on the phy (init,deinit,on,off)
- the behavior of the uclass when optional operations are not implemented
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Rather than using CMD_CRAMFS for both the filesystem and its command, we
should have a separate option for each. This allows us to enable CRAMFS
support without the command, if desired, which reduces U-Boot's size
slightly.
[trini: imply FS_CRAMFS for keymile]
CONFIG_CMD_CRAMFS
[trini: imply CMD_CRAMFS for keymile]
Rather than using CMD_CBFS for both the filesystem and its command, we
should have a separate option for each. This allows us to enable CBFS
slightly.
[trini: imply FS_CBFS on SYS_COREBOOT]
CONFIG_CMD_CBFS
[trini: imply CMD_CBFS on SYS_COREBOOT]
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
Unfortunately a test for the PWM uclass was not included when it was
submitted. This was noticed when trying to add more functionality:
http://patchwork.ozlabs.org/patch/748172/
Add a simple test to get us started.
Allow LEDs to be blinked if the driver supports it. Enable this for
sandbox so that the tests run.
Reviewed-by: Ziping Chen <techping.chan@gmail.com>
Boards with an apparent need for the md5sum command had the connected
config symbol defined in their board header file.
Move this over to the respective defconfig files now that md5sum is
configured via Kconfig.
(This is a manual effort, which differs from moveconfig.py, not sure
who is right here. Boards except sandbox loose the md5sum command with
moveconfig.py, though it was explicitly mentioned in their config.h's)
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[trini: migrate stih410-b2260]
[1] Rename CONFIG_SANDBOX_MMC to CONFIG_MMC_SANDBOX for consistency
I want all MMC driver options prefixed with CONFIG_MMC_.
[2] Fix dependency
Add necessary depends on to avoid compile error.
Instead "depends on MMC" is unneeded because this config entry
resides inside of "if MMC".
[3] Currently, this config symbol is not referenced at all.
Use it to enable/disable the driver in Makefile.
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Signed-off-by: Jagan Teki <jagan@openedev.com>
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
This commit was created as follows:
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
A number of platforms had been using the distro default feature before
it was moved to Kconfig but did not enable the new Kconfig option when
it was enabled. This caused a regression in terms of features and this
introduces breakage when more things move to Kconfig.
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
Reviewed-by: Jagan Teki <jteki@openedev.com>
[trini: Re-migrate, update common/console.c logic]
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892.
I took a closer look at this after the commit was applied, and found
CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is
actually too big for some boards. Perhaps 0x800 is enough, but the
situation varies board by board.
Let's postpone our decision until we come up with a better idea.
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind
several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently
not enough. Increase the default to 0x2000 for the case. This
will be helpful for shorter defconfigs.
Enable this feature so that we can use it for testing in sandbox_spl.
It is useful to be able to build SPL for sandbox. It provides additional
build coverage and allows SPL features to be tested in sandbox. However
it does not need worthwhile to always create an SPL build. It nearly
doubles the build time and the feature is (so far) seldom used.
So for now, create a separate build target for sandbox SPL. This allows
experimentation with this new feature without impacting existing workflows.
